FRAME / El Camino 650b, Alloy 6061 formed
FORK / SUNTOUR XCM HLO, hydraulic mechanical lock out, travel 100mm on XS/S, 120mm on M/L/XL, 1"1/8 steerer, 9mm front axle
HEADSET / 1’’1/8, Semi integrated, ball retainer
STEM / COMMENCAL 60mm, Ø31,8mm, 10° angle
BAR / COMMENCAL Ø31,8mm, alloy 6061, 1’’ RISE, 700MM XS/S ; 720MM M/L/XL
GRIPS / COMMENCAL, Ø32mm, SOFT COMPOUND
BRAKES / TEKTRO HDM290 hydraulic disc brake 180mm/160mm, with reach adjustement
SHIFTERS / SRAM X4 3x8 spd
FRONT MECH / SRAM 3.0 3 spd
REAR MECH / SRAM X4 8 spd
BOTTOM BRACKET / BB 68mm, Cartridge bearing
CRANKS / Square Taper 22/32/42T, 170mm on S, 175mm on M/L/XL
CHAIN / YABAN 8 spd
CASSETTE / SRAM PG820 11-32t
RIMS / COMMENCAL 650B 32H double wall, 24,5mm, pin joint
HUBS / COMMENCAL 32H, double sealed loose ball
SPOKES / Spoke Steel 1,8mm black - nipple brass 12mm black
TIRES / MAXXIS Ardent 2.25, 60 tpi
SEATPOST / COMMENCAL alloy no offset Ø31,6mm, 350mm
SADDLE / COMMENCAL El Camino, steel black rails, soft padding
INCLUDES / WELLGO Low Profile flat pedals, Chainstay protector
COLOUR / Matt Black
BIKE WEIGHT(kg/lbs) / 13,8 kg
Je pense que la fourche sera à changer en priorité dès que possible
